StarTech.com HDMI to VGA Video Adapter Converter with Audio f...
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook
£29.62
Delivery:
Standard: 1-3 working days
Key features
  • Easily make your new HDMI equipment (Desktop, Laptop, or Ultrabook) compatible with a VGA display (Television, Monitor, Projector)
  • With support for up to 1080p video and 2 channel audio
  • No power adapter required
  • Stock Status: In Stock
Product codes
Convert an HDMI video signal to VGA, with discrete audio output. The HD2VGAA2 HDMI to VGA Adapter Cable enables you to connect an HDMI output device, such as a laptop video output or digital media extender to a VGA display device (monitor, projector) by converting the HDMI video signal from the output device into a VGA output and separate 2-channel analog audio. The HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor. The adapter can also extend your computer's desktop to double your workspace and increase productivity.
The versatile converter supports resolutions including high definition 1080p, up to 1920x1200, which eliminates the expense of upgrading a VGA display for the sake of compatibility, and doesn't require a separate power adapter which saves installation time and hassle.
Product Description StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook - 1920x1080 - video interface converter - HDMI / VGA / audio - 25 cm
Cable Video interface converter - HDMI / VGA / audio
Max Output Resolution 1920 x 1080 - 60 Hz
Length 25 cm
Colour Black
Connectors HDMI - male (input)
Connectors (Second End) HD-15 (VGA) - female (output) , Mini jack - female (output) , Micro-USB Type B - female
Features 1080p support, active adapter
Designed For P/N: DK30CH2DEP, DK30CH2DEPUE, MST30C2DPPD
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HDMI to V...
£29.62
