Convert an HDMI video signal to VGA, with discrete audio output. The HD2VGAA2 HDMI to VGA Adapter Cable enables you to connect an HDMI output device, such as a laptop video output or digital media extender to a VGA display device (monitor, projector) by converting the HDMI video signal from the output device into a VGA output and separate 2-channel analog audio. The HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor. The adapter can also extend your computer's desktop to double your workspace and increase productivity.
The versatile converter supports resolutions including high definition 1080p, up to 1920x1200, which eliminates the expense of upgrading a VGA display for the sake of compatibility, and doesn't require a separate power adapter which saves installation time and hassle.
Product Description | StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook - 1920x1080 - adapter - HDMI / VGA / audio - 25 cm | Cable | Adapter - HDMI / VGA / audio | Max Output Resolution | 1920 x 1080 - 60 Hz | Length | 25 cm | Colour | Black | Connectors | HDMI - male (input) | Connectors (Second End) | HD-15 (VGA) - female (output) , Mini jack - female (output) , Micro-USB Type B - female | Features | 1080p support, active adapter | Manufacturer Warranty | 3-year warranty | Designed For | P/N: DK30CH2DEP, DK30CH2DEPUE, MST30C2DPPD |
General | |
Cable Type | Adapter 1080p support, active |
Interface Supported | HDMI / VGA / audio |
Jacket Material | Plastic |
Length | 25 cm |
Features | Multi-channel audio |
Colour | Black |
Adapters & Converters | |
Max Output Resolution | 1920 x 1080 |
Refresh Rate | 60 Hz |
Connectivity | |
Connectors | 19 pin HDMI Type A - male (input) |
Connectors (Second End) | 15 pin HD D-Sub (HD-15) - female (output) , Mini-phone 3.5 mm - female (output) , 5 pin Micro-USB Type B - female |
Miscellaneous | |
Compliant Standards | FCC, RoHS, WEEE, REACH, RCM |
Dimensions & Weight | |
Width | 4.5 cm |
Height | 1.5 cm |
Weight | 36 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 8 cm |
Shipping Depth | 18 cm |
Shipping Height | 2 cm |
Shipping Weight | 66 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
