StarTech.com High Resolution VGA to Composite (RCA) or S-Vide...
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV
£85.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with any PC/Notebook with a VGA out video card
  • Easy to use and install
  • Pure hardware design that automatically detects the scan rate and resolution of the incoming graphic signals without the use of software
  • With support for high resolutions and automatic scaling there is no need to lower resolution settings on your PC
  • Type: VGA
  • Stock Status: In Stock
Product codes
Connect a PC with VGA output to a composite or S-video TV. This high resolution VGA to composite or S-video converter is a simple hardware solution that allows you to convert a VGA/PC video signal into a composite or S-video signal for use with a CRT or flat panel display.
The ideal solution for synchronizing monitors with television displays etc., the VGA to composite/S-video converter offers selectable NTSC or PAL format operating modes to ensure compatibility with virtually any configuration.
Product Description StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV Video Adapter - 1600x1200 RGB to TV (VGA2VID) - video converter - black
Device Type Video converter
Max Resolution 1152 x 864
Interfaces 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video output - 4 pin mini-DIN , 1 x composite video output - RCA
Enclosure Colour Black
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com High Reso...
£85.99
