StarTech.com HP J9150D Compatible SFP+ MM Module - 10GBase-SR
£136.99
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with HP J9150D guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
Product codes
The J9150D-ST is a HP J9150D compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 300 m (984 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com HPE J9150D Compatible SFP+ Module, 10GBASE-SR, 10GbE Multi Mode Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 300m, 850nm, DDM, HPE FlexFabric, 6120XG, 6120G - Lifetime Warranty (J9150D-ST) - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 300 m
OEM Manufacturer Equivalent Part Number HP J9150D
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.37 cm
Weight 20 g
Designed For HPE Aruba 2540 24, 2540 48, 2930F 12, 2930F 48, 2930F 8G, 2930M 24, 2930M 40, 2930M 48, 3810M 24, 3810M 48, 5406R 16, 5406R 44, 5406R 8-port, 5406R zl2, 5412R 92, 5412R zl2, 54XX, 6200F 12, 6200M 24, 6300, 6405 48, 6405 96, 64XX, 70XX, 72XX, 83XX, 8400, 8400 8-slot; CX 8360; Instant On 1930 48
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£136.99
