StarTech.com HP JD092A Compatible SFP+ MM Module - 10GBase-SR
£45.30
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with HP JD092A guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
The JD092A-ST is a HP JD092A compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 300 m (984 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com HP JD092A Compatible SFP+ Module - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 300 m
OEM Manufacturer Equivalent Part Number HP JD092A
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.37 cm
Weight 20 g
Designed For HPE 7502, 7503-S Switch with 1 Fabric Slot, 7506, 7506-V, 9505, 9508-V, 9512; FlexNetwork 7503, 7510 Switch with 2x2.4Tbps Fabric and Main Processing Unit
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HP JD092A...
£45.30
