StarTech.com In-Wall 300 Mbps 2T2R Wireless-N Access Point -...
StarTech.com In-Wall 300 Mbps 2T2R Wireless-N Access Point - 2.4GHz 802.11b/g/n PoE-Powered WiFi AP
£80.19
Delivery:
Key features
  • Discreet in-wall installation, into a standard 1-gang wall box
  • Ensure fast, reliable network connectivity, with full Wireless-N compatibility
  • Use existing infrastructure wiring to create a wireless hot-spot, through the PoE-powered design
Product codes
Install a PoE-Powered, in-wall 802.11b/g/n access point with 2 RJ45 LAN / phone ports. This in-wall access point provides network and internet availability for both wired and wireless users. The sleek in-wall design with PoE enables you to use your existing CAT5 infrastructure to easily replace your standard RJ45 jacks, adding the benefits of dual LAN ports and Wireless-N connectivity.
This access point can be discretely integrated into any room where internet or network access is required. The wireless AP installs into any standard 1-gang receptacle box and features an elegant design for a seamless integration into any modern space. The sleek design ensures a tidy professional installation that is perfect for hotel rooms, hospitals, offices and schools.
The wireless access point is powered using Power over Ethernet to conveniently connect both data and power using an 802.3af PoE switch or injector, avoiding the hassle of in-wall power or external power adapters. The access point offers two front RJ45 Ethernet ports, with the first operating over the PoE connection and the second offering a transparent pass-through port that can be used for either a phone connection or a secondary LAN drop. The easy-to-incorporate nature of this AP is ideal for system integrators when planning the construction phase of schools, offices or residential buildings.
For fast performance the wireless AP is compatible with 802.11b/g/n standard supporting wireless data rates up to 300 Mbps on the 2.4GHz frequency. For a secure connection the access point supports WEP, WPA, and WPA2 authentication. The device also incorporates an easy-to-use web-based utility to provide several customization options such as multiple SSIDs, remote firmware upgrades and event reporting.
StarTech.com In-Wall 300 Mbps 2T2R Wireless-N Access Point - radio access point
Radio access point
In-wall mountable
MediaTek MT7620n
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
3.9 cm x 7.2 cm x 5.5 cm
84 g
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com In-Wall 3...
£80.19
