We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This industrial 5-port gigabit PoE switch (4-port PoE) features 30W of power and is designed to be installed in harsh environments and supports up to a total of 120W power outputs.
Product Description | StarTech.com Industrial 5 Port Gigabit PoE Switch, 30W, Power Over Ethernet Switch, Hardened GbE PoE+ Unmanaged Switch, Rugged High Power Gigabit Network Switch IP-30 Housing/-40 C to 75 C - Gigabit Ethernet PoE (IESC1G50UP) - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 4 x 10/100/1000 (PoE+) + 1 x 10/100/1000 | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 120 W | Jumbo Frame Support | 9KB | Features | Flow control, full duplex mode, rugged, 2KV ESD Protector, Back Pressure Support, Media Dependent Interface Crossover (MDI-X) | Compliant Standards | IEEE 802.3, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at | Power | DC 48 - 56 V | Dimensions (WxDxH) | 8.15 cm x 10.4 cm x 3.2 cm | Weight | 150.6 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | DIN rail mountable, wall-mountable |
Status Indicators | Power, PoE, link |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 , 1 x terminal block |
Power | |
Voltage Required | DC 48 - 56 V |
Power Consumption Operational | 126 Watt |
Miscellaneous | |
Colour | Black |
Included Accessories | Terminal block connector, mounting kit |
MTBF | 538451 hours |
Compliant Standards | IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, UL 60950-1, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6 |
Dimensions & Weight | |
Width | 8.15 cm |
Depth | 10.4 cm |
Height | 3.2 cm |
Weight | 150.6 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.1 cm |
Shipping Depth | 16.2 cm |
Shipping Height | 6.4 cm |
Shipping Weight | 392.6 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 75 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
