We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Easily deploy or scale your network with this Gigabit Ethernet switch, features four dedicated PoE+ enabled ports, and one dedicated open SFP slot plus the flexibility of a switchable SFP port for use as an uplink or for non-PoE devices.
Product Description | StarTech.com Industrial 6 Port Gigabit Ethernet Switch 4 PoE RJ45 +2 SFP Slots 30W PoE+ 48VDC 10/100/1000 Power Over Ethernet LAN Switch -40C to 75C, DIN Connector/Mountable, Fast Ethernet - High Power PoE Switch (IES1G52UPDIN) - switch - 6 ports | Device Type | Switch - 6 ports | Subtype | Gigabit Ethernet | Ports | 1 x 10/100/1000 + 4 x 10/100/1000 (PoE+) + 2 x SFP | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 120 W | Performance | Switching fabric speed: 12 Gbps | Jumbo Frame Support | 9KB | Features | Flow control, full duplex mode, 1MB packet buffer, 2KV ESD Protector, Media Dependent Interface Crossover (MDI-X) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at | Power | DC 48 - 56 V | Dimensions (WxDxH) | 10.5 cm x 14.2 cm x 3.6 cm | Weight | 492 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | DIN rail mountable |
Status Indicators | Power, PoE, SFP, link |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x SFP , 1 x terminal block |
Power | |
Voltage Required | DC 48 - 56 V |
Power Consumption Operational | 126 Watt |
Miscellaneous | |
Colour | Black |
Included Accessories | Terminal block connector, mounting kit |
MTBF | 525,058 hours |
Compliant Standards | IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, UL 60950-1, EN 60950-1, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6 |
Dimensions & Weight | |
Width | 10.5 cm |
Depth | 14.2 cm |
Height | 3.6 cm |
Weight | 492 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.1 cm |
Shipping Depth | 16.2 cm |
Shipping Height | 6.4 cm |
Shipping Weight | 700 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 75 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 80 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
