StarTech.com Industrial Gigabit PoE Injector 90W 802.3bt PoE+...
StarTech.com Industrial Gigabit PoE Injector 90W 802.3bt PoE++ UPoE
£217.88
Delivery:
Standard: 1-3 working days
Key features
  • WIDE STANDARD COMPATIBILITY: High speed Industrial Gigabit PoE Injector compatible w/ IEEE 802.3bt (PoE++) & previous 90W proprietary POE standards including PoH (HDBase-T), Cisco uPoE, Bosch & AXIS
  • 90W POWER BUDGET: Provides up to 90W of auto-negotiated power output for Type 3 and Type 4 PoE/Ultra/UPoE applications like tilt and pan cameras and high power IEEE 802.11ax wireless access points
  • TECH SPECS: 1 Gbps | 52V-56VDC Power Input | IEEE 802.3af | IEEE 802.3at | IEEE 802.3bt 90W max | PoH (HDBase-T) | uPoE | 10/100/1000 Mbps Auto Negotiation | DIN/Wall Mountable | Redundant Power Input
  • ROBUST DESIGN: Industrial Power over Ethernet Injector w/MTBF of 500,000+hrs @ 50C | Vibration, shock & free fall rated | Rugged IP-30 aluminum housing | Hardened operating temp of -40C to 75C
  • STARTECH.COM ADVANTAGE: IT professionals' choice for over 30 years | This PoE Injector is backed for 2-years by StarTech.com, including free 24/5 North America based multi-lingual tech support
Product codes
This Gigabit Power over Ethernet (PoE+) injector supplies power and data connectivity to a Gigabit PoE-compliant device using a standard Ethernet cable.
Product Description StarTech.com Industrial Gigabit PoE Injector, High Speed/High Power 90W, 802.3bt PoE++ 48V-56VDC DIN Rail UPoE/Ultra Power Over Ethernet Injector Adapter, -40C to +75C, Rugged, Gigabit PoE - 90W PoE++ Injector (POEINJ1G90W) - PoE injector - 90 Watt
Device Type PoE injector - external
Power Over Ethernet (PoE) PoE++
Weight 174 g
Output Voltage 48 - 56 V
Power Capacity 90 Watt
Output connectors 1 x RJ-45
Included Accessories Mounting kit, terminal block
Colour Black
Dimensions (WxDxH) 3.2 cm x 8.2 cm x 10.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£217.88
