StarTech.com Industrial RS232 to RS422/485 Serial Port Conver...
StarTech.com Industrial RS232 to RS422/485 Serial Port Converter with 15KV ESD Protection
£64.45
13 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Convert an RS232 data signal to either RS485 or RS422 with this wall-mountable, ESD-protected adapter. The IC232485S Industrial RS232 to RS-422/485 Serial Converter is a bi-directional adapter that lets you adapt an RS232 data signal to either RS485 (2 or 4-wire) or RS422 and vice-versa, with support for baud rates up to 921.6 Kbps.
Ideal for industrial environments, the serial port converter provides 15KV ESD protection on all signal pins to protect costly and often sensitive control equipment against electrical damage. The serial converter also features a sturdy wall-mountable metal housing with Power, Tx and Rx LED indicators for simple status monitoring.
The adapter supports auto baud rate detection as well as RS-422 and RS485 mode detection, with an integrated dip switch for manual mode selection if needed, and supports connection distances of up to 4000ft (1200m).
Product Description StarTech.com Industrial RS232 to RS422/485 Serial Port Converter w/ 15KV ESD Protection - RS232 to RS 422 RS485 Converter Adapter (IC232485S) - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type Serial RS-232
Ports RS-422/485 x 1
Dimensions (WxDxH) 5.9 cm x 11.7 cm x 2.2 cm
Weight 150 g
Data Link Protocol RS-422, RS-485
Data Transfer Rate 921.6 bps
Colour Black
Power AC 120/230 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Industria...
£64.45
