This TAA-compliant 10-port industrial USB 2.0 Hub delivers scalability and protection in harsh industrial environments by providing a high number of USB ports with ESD level 4 protection. The durable metal housing construction is ideal for industrial applications. For power connectivity, the Hub features power redundancy using the DC barrel plug and terminal block port. Finish the installation by mounting the Hub to a DIN rail using the included hardware or on a desk or wall with the built-in mounting brackets.
Product Description | StarTech.com 10-Port Industrial USB 2.0 Hub, Rugged USB Hub w/15kV Air/8kV Contact ESD Level 4 Protection, DIN/Wall/Desk Mountable USB-A Hub, Multiport USB Hub with Locking Ports - Metal Construction (USB210AIND-USB-A-HUB) - hub - industrial - 10 ports - TAA Compliant | Device Type | Hub - 10 ports | Subtype | USB | Ports | 10 x USB 2.0 | Features | 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), steel housing, integrated mounting bracket, lockable ports | Compliant Standards | USB 1.1, USB 2.0 | Dimensions (WxDxH) | 5.6 cm x 19.8 cm x 3.1 cm | Weight | 340 g | Colour | Black | TAA Compliant | Yes | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop, DIN rail mountable, wall-mountable |
Subtype | USB |
Processor | X Terminus Tech FE2.1 |
Status Indicators | Power |
Expansion / Connectivity | |
Interfaces | 10 x USB 2.0 Type A , 1 x USB 2.0 Type B host , 1 x terminal block |
Miscellaneous | |
Colour | Black |
Included Accessories | Mounting screws, 2 DIN-rail mounting brackets |
Cables Included | 1 x USB-B to USB-A screw-lock cable - 1.8 m |
Compliant Standards | WEEE, RCM |
Dimensions & Weight | |
Width | 5.6 cm |
Depth | 19.8 cm |
Height | 3.1 cm |
Weight | 340 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 16.8 cm |
Shipping Depth | 24.5 cm |
Shipping Height | 5.5 cm |
Shipping Weight | 600 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 5 - 95% RH |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 75 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
