StarTech.com IP67 Certified 2.4GHz Outdoor Wireless-N Access...
StarTech.com IP67 Certified 2.4GHz Outdoor Wireless-N Access Point -WiFi AP
£150.32
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Withstand the harsh elements, with the rugged metal IP67 rated housing
  • Customize your wireless network as needed, with support for several operating modes
  • Deploy a PoE network device in remote locations with a secondary PoE pass-through LAN port
Product codes
Add 2.4 GHz Wi-Fi coverage to an outdoor area, with a ruggedized industrial access point - PoE Powered. The R300WN22ODG Outdoor Wireless Access Point lets you add 2.4 GHz Wireless-N network coverage to an outdoor area, through a ruggedized industrial access point.
This outdoor access point features an IP67 certified, die-cast metal enclosure with heavy-duty cable grommets so it can withstand the outdoor elements and offers pole and wall-mounting options. Plus, the PoE-powered AP includes a passive Power-over-Ethernet injector, enabling you to install it in locations where a typical power outlet is unavailable. PoE pass-through via the secondary LAN port lets you connect data and power to a PoE-capable device near the access point.
For optimal wireless coverage, the AP broadcasts a signal through a high-powered 800 mW internal 10 dBi 2T2R antenna, with 802.11b/g/n compatibility to easily connect most wireless devices new or old.
The device offers support for several different operating modes (AP, WDS and WISP), which help you to create a wireless network from a wired connection, bridge multiple APs together or extend the range of an existing wireless network. The AP supports Wireless-N data rates up to 300 Mbps with security through WEP, WPA, or WPA2 authentication, all configurable through an easy-to-use web-based utility.
StarTech.com IP67 Certified Outdoor 300 Mbps 2T2R Wireless-N Access Point - radio access point
Radio access point
External - outdoor
United Kingdom
Atheros AR9341
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
9.6 cm x 15.8 cm x 4.9 cm
820 g
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com IP67 Cert...
£150.32
