StarTech.com IP67 Certified 2T2R 5GHz Outdoor Wireless-N Acce...
StarTech.com IP67 Certified 2T2R 5GHz Outdoor Wireless-N Access Point - 300 Mbps WiFi AP
£151.94
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Withstand the harsh elements, with the rugged metal IP67 rated housing
  • Operate efficiently with less interference from other devices, through 5Ghz operation at 300Mbps
  • Customize your wireless network as needed, with support for several operating modes
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 300Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11n
  • Compatibility: PC
Product codes
Add 5 GHz Wi-Fi coverage to an outdoor area, with a ruggedized industrial access point - PoE Powered. The R300WN22MO5G Outdoor Wireless Access Point lets you add 5 GHz Wireless-N network coverage to an outdoor area, through a ruggedized industrial access point.
This outdoor access point features an IP67 certified, die-cast metal enclosure with heavy-duty cable grommets so it can withstand the outdoor elements and offers pole and wall-mounting options. Plus, the PoE-powered AP includes a passive Power-over-Ethernet injector, enabling you to install it in locations where a typical power outlet is unavailable. PoE pass-through via the secondary LAN port lets you connect data and power to a PoE-capable device near the access point.
By isolating your Wi-Fi network to the 5 GHz frequency, dual-band smartphones, tablets or laptops can operate with less interference from other devices than on the more common 2.4 GHz band. For optimal wireless coverage, the AP broadcasts a signal through a high-powered 800 mW internal 10 dBi 2T2R antenna.
The device offers support for several different operating modes, which help you to create a wireless network from a wired connection, bridge multiple APs together or extend the range of an existing wireless network. The AP supports Wireless-N data rates up to 300 Mbps with security through WEP, WPA, or WPA2 authentication, all configurable through an easy-to-use web-based utility.
Product Description StarTech.com IP67 Certified 5GHz Outdoor Wireless-N Access Point - WiFi AP - radio access point
Device Type Radio access point
Form Factor External - outdoor
Localisation United Kingdom
Processor Atheros AR9342
Data Link Protocol IEEE 802.11a, IEEE 802.11n
Frequency Band 5 GHz
Included Accessories PoE injector
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 9.6 cm x 15.8 cm x 4.9 cm
Weight 820 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com IP67 Cert...
£151.94
