StarTech.com J9151A-BX-U SFP Module - Lifetime Warranty - 10...
StarTech.com J9151A-BX-U SFP Module - Lifetime Warranty - 10 Gbps - LC SF
£113.67
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with HP J9151A-BX-U guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Pairs with J9151A-BX-D-ST
  • Stock Status: In Stock
Product codes
The J9151A-BX-U-ST is an HP J9151A compatible upstream fiber SFP+ transceiver which pairs with StarTech.com's J9151A-BX-D-ST. They are designed, programmed and tested to work with 10GBase-BX compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ Cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com HPE J9151A Compatible SFP+ Module - 10GBASE-BX - 10 GbE Gigabit Ethernet BiDi Single Mode Fiber (SMF) Transceiver Module - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 10GBase-BX
Data Transfer Rate 10 Gbps
Optical Wave Length 1270 nm / 1330 nm
Data Link Protocol 10 GigE
Max Transfer Distance 10 km
OEM Manufacturer Equivalent Part Number HP J9151A-BX-U
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.26 cm
Weight 24 g
Designed For HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com J9151A-BX...
£113.67
