StarTech.com Juniper CTP-SFP-1GE-T Comp SFP Copper Module - 1...
StarTech.com Juniper CTP-SFP-1GE-T Comp SFP Copper Module - 1000Base-T -
£53.10
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Juniper CTP-SFP-1GE-T guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic set ups
Product codes
The CTPSFP1GETST is a Juniper CTP-SFP-1GE-T compatible copper transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Juniper CTP-SFP-1GE-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps/1000Mbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (CTPSFP1GETST) - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - RJ-45
Form Factor Plug-in module
Cabling Type 1000Base-T
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Max Transfer Distance 100 m
OEM Manufacturer Equivalent Part Number Juniper CTP-SFP-1GE-T
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£53.10
