StarTech.com Juniper RX-GET-SFP Comp SFP Copper Module - 1000...
StarTech.com Juniper RX-GET-SFP Comp SFP Copper Module - 1000Base-T
£44.53
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Juniper RX-GET-SFP guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic set ups
  • Stock Status: In Stock
Product codes
The RXGETSFPST is a Juniper RX-GET-SFP compatible copper transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Juniper RX-GET-SFP Compatible SFP Module - 1000BASE-T - 1GE Gigabit Ethernet SFP to RJ45 Cat6/Cat5e Transceiver - 100m - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - RJ-45
Form Factor Plug-in module
Cabling Type 1000Base-T
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Max Transfer Distance 100 m
OEM Manufacturer Equivalent Part Number Juniper RX-GET-SFP
Dimensions (WxDxH) 1.4 cm x 6.5 cm x 1.2 cm
Weight 72 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Juniper R...
£44.53
