StarTech.com Juniper SFP-GE40KT15R13 Comp SFP SM Module - 100...
StarTech.com Juniper SFP-GE40KT15R13 Comp SFP SM Module - 1000Base-BX40-D
£136.92
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Juniper SFP-GE40KT15R13 guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
The SFPGE40KT5R3 is a Juniper SX compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-BX40-D compliant networks, with a maximum distance of up to 2 km (1.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Juniper SFP-GE40KT15R13 Compatible SFP Module - 1000BASE-BX-D - 10 GbE Gigabit Ethernet BiDi Fiber (SMF) - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 1000Base-BX40-D
Data Transfer Rate 1 Gbps
Optical Wave Length 1310 (TX) / 1550 (RX) nm
Data Link Protocol GigE
Max Transfer Distance 40 km
OEM Manufacturer Equivalent Part Number Juniper SFP-GE40KT15R13
Dimensions (WxDxH) 1.4 cm x 6.5 cm x 1.2 cm
Weight 72 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Juniper S...
£136.92
