StarTech.com KVM Console to USB 2.0 Portable Laptop Crash Car...
£368.31
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ultra high resolution support up to 1920 x 1200 @ 60Hz – The highest resolution portable console available
  • No power adapter needed - Draws power from the server side USB connection saving your laptop’s battery life, and avoiding the hassle of finding 110V outlets in the server room or remote locations
  • Small, ruggedized casing (similar to the size of a cellphone) is easily stored and transported; with no server-side software requirement, you will be up and running in seconds
Product codes
Turn any laptop into a console for headless servers, PCs, ATMs, Kiosks and more! StarTech.com's USB 2.0 Laptop KVM Adapter turns your notebook or netbook into a guininely portable server crashcart, eliminating the need to lug around a large, heavy and awkward video screen, keyboard, and mouse. This adapter delivers the VGA stream from any host computer to a laptop and emulates the laptop mouse and keyboard outputs, for simple access and control of connected servers, PCs or other "headless" devices.
With portability for the mobile administrator or repair technician in mind, this self-powered adapter features a small-footprint design that requires no additional accessories to connect to most servers, and requires no server-side software installation. Plus, the pocket-sized adapter draws its power from the server-side connections, allowing the laptop/netbook to last longer without consuming battery power.
Ensuring full control of the connected units, the Laptop KVM Server Console Adapter provides immediate access to the BIOS post and the ability to handle full configuration of the attached PC or machine; administrators can connect to a headless server/device without the need of an expensive LCD rackmount console or bulky monitor, keyboard, and mouse solution.
StarTech.com KVM Console to USB 2.0 Portable Laptop Crash Cart Adapter - KVM switch - 1 ports
Subtype
KVM
Ports
1 x KVM port(s)
KVM Users Qty
1 local user
Firmware upgradable
7.4 cm x 11.5 cm x 1.5 cm
172 g
Windows 10 (32/64 bits)
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com KVM Conso...
£368.31
