StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit...
StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination
£21.38
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Protect your laptop or other device against theft using this cable lock, with a 3-digit resettable combination
  • Portable self-coiling cable lock stretches to 1.8 m (6'), and retracts to just 266 mm (10.5")
  • Compatible with laptops, docks, monitors, projectors or other computer equipment with a Kensington lock slot (K-Slot)
  • Tamper-resistant vinyl-coated steel cable (3.2 mm diameter)
  • Strong and durable lock head
  • Type: Security
  • Stock Status: In Stock
Product codes
Marketing description is not available.
Product Description StarTech.com Laptop Combination Cable Lock - Self-Coiling Cable - 3-Digit security cable lock
Product Type Security cable lock
Product Material Vinyl, steel
Dimensions (WxDxH) 1.3 cm 2.03 cm
Length 1.8 m
Weight 118 g
Features Resettable function
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Laptop Ca...
£21.38
