StarTech.com Laptop Cable Lock Anchor - Computer Security Cab...
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor
£13.75
49 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Help protect your laptop, dock or other device against theft by adding a secure anchor point for a cable lock
  • Helps deter theft with durable zinc alloy construction
  • Easy to attach to solid surfaces using included screws and adhesive backing
  • Supports keyed or combination cable locks
  • Small footprint makes it easy to find a place to secure your device
  • Type: Security
Product codes
Now you can help to guard your laptop, docking station or other device against theft. This laptop cable lock anchor attaches easily to a solid surface, to provide a strong and secure anchor point for your cable lock (sold separately).
Protect your device, and your investment, by adding a secure lock anchor point to a desk, counter, cabinet, wall or other solid location. The computer security-cable anchor features a small footprint and is easy to attach using two screws and the adhesive pad(included). It gives you the convenience of choosing the location of the anchor point for your cable lock.
Made of stainless steel, the ringed desk mount cable anchor can withstand a strong force from the cable lock in all directions. The robust steel construction helps to prevent the anchor point from being tampered with or cut. The steel security plate prevents access to the mounting screws.
Product Description StarTech.com Laptop Cable Lock Anchor - Zinc Alloy - Computer Security Cable Anchor - Desk Mount Security Anchor Point - Screw-On Lock Anchor (LTANCHOR) - lock anchor
Product Type Lock anchor
Package Content Cleaning wipe, pad, 2 wood screws
Colour Silver
Product Material Steel
Dimensions (WxDxH) 4.4 cm x 4.58 cm x 2.79 cm
Weight 61 g
Designed For P/N: LTLOCKNBL
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£13.75
