Now you can help to guard your laptop, docking station or other device against theft. This laptop cable lock anchor attaches easily to a solid surface, to provide a strong and secure anchor point for your cable lock (sold separately).
Protect your device, and your investment, by adding a secure lock anchor point to a desk, counter, cabinet, wall or other solid location. The computer security-cable anchor features a small footprint and is easy to attach using two screws and the adhesive pad(included). It gives you the convenience of choosing the location of the anchor point for your cable lock.
Made of stainless steel, the ringed desk mount cable anchor can withstand a strong force from the cable lock in all directions. The robust steel construction helps to prevent the anchor point from being tampered with or cut. The steel security plate prevents access to the mounting screws.
Product Description | StarTech.com Laptop Cable Lock Anchor - Zinc Alloy - Computer Security Cable Anchor - Desk Mount Security Anchor Point - Screw-On Lock Anchor (LTANCHOR) - lock anchor | Product Type | Lock anchor | Package Content | Cleaning wipe, pad, 2 wood screws | Colour | Silver | Product Material | Steel | Dimensions (WxDxH) | 4.4 cm x 4.58 cm x 2.79 cm | Weight | 61 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: LTLOCKNBL |
General | |
Width | 4.4 cm |
Depth | 4.58 cm |
Height | 2.79 cm |
Weight | 61 g |
Colour | Silver |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 2 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
