StarTech.com Laptop Cable Lock Anchor - Large
£16.10
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Help protect your laptop, dock or other device against theft by adding a secure anchor point for a cable lock
  • Anchor point with large 1.4” W x 0.7” H (35 x 19 mm) ring opening provides versatile use with thicker cable locks, or multiple cables
  • Easy to attach to solid surfaces using included screws and adhesive backing
  • Stock Status: In Stock
Product codes
Create a versatile and secure anchor point in almost any location, to help guard your laptop, docking station or other device against theft. This laptop cable-lock anchor features a large ringed design that attaches easily to a solid surface, to provide a strong and secure anchor point for your cable lock (sold separately).
With its large ringed design, the cable lock anchor point provides ample room to thread thicker cable locks, or more than one cable through the 1.4" W x 0.7" H (35 x 19 mm) opening.
Protect your device, and your investment, by adding a laptop cable-lock anchor point to a desk, counter, cabinet, wall or other solid location. The screw-on cable lock anchor makes it easy to lock your laptop to your desk. It features a small footprint and is easy to attach using two screws and the adhesive pad (included). It gives you the convenience of choosing the location of the anchor point for your cable lock.
Made of durable zinc alloy, the ringed deskmount security anchor point can withstand a strong force from the cable lock in all directions. The robust construction of the computer security cable anchor helps to prevent the anchor point from being tampered with or cut. The security plate prevents access to the mounting screws.
Product Description StarTech.com Laptop Cable Lock Anchor - Large - Security Cable Anchor Point lock anchor
Product Type Lock anchor
Package Content Cover plate, 2 wood screws, abrasive pad, alcohol wipe
Colour Silver
Product Material Steel
Dimensions (WxDxH) 6.7 cm x 4.7 cm x 3.1 cm
Weight 100 g
Designed For P/N: LTLOCKNBL
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Laptop Ca...
£16.10
