StarTech.com Laptop Lock - 6' Steel Cable
£13.59
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Security
  • Stock Status: In Stock
Product codes
Protect your laptop against theft with this convenient combination lock. This laptop lock gives you an easy and effective way to secure your laptop to a sturdy object and keep it safe from theft. With this 4-digit combination lock, you can be confident your laptop and valuable data are well protected.
You can ensure that your laptop, monitor, docking station or other electronic device will be anchored safely to your workspace in just a few simple steps with this keyless 4-digit combination lock. It effortlessly latches directly into any laptop or other device equipped with a built-in security-lock slot, providing dependable theft prevention in a wide range of retail, commercial, and institutional environments.
Featuring a vinyl-coated steel cable (6 mm diameter), this laptop lock is designed for effective theft prevention.
Product Description StarTech.com Laptop Lock security cable lock
Product Type Security cable lock
Colour Black & silver
Product Material Vinyl, steel
Dimensions (WxDxH) 0.6 cm 0.6 cm
Length 1.8 m
Weight 182 g
Designed For P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, USB3DDOCKFT, USB3DOCKH2DP, USB3VDOCK4DP, USB3VDOCKD
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Laptop Lo...
£13.59
