StarTech.com Low Profile 16in Parallel Port Header Cable Adap...
StarTech.com Low Profile 16in Parallel Port Header Cable Adapter with Bracket – DB25 (F) to IDC26
£5.79
28 in stock
Delivery:
Standard: 1-3 working days
  • Length: 40.64cm
  • Stock Status: In Stock
Product codes
Add a 25-pin parallel port to the back of your low profile/small form factor computer from your motherboard. The PLATE25F16LP DB25 to IDC26 Parallel Port Bracket adds a DB25 parallel port to the rear panel of a low profile/small form factor computer, which connects to an IDC26 header connector on the motherboard.
Constructed of only top quality components, the Parallel Port Header Cable offers a cost-effective solution for adding a parallel device connection using a compatible motherboard.
Product Description StarTech.com Low Profile 16in Parallel Port Header Cable Adapter w/ Bracket - DB25 to IDC26 Parallel Port Bracket DB-25 (F) to IDC 26 (F) (PLATE25F16LP) - parallel panel - 40.64 cm
Type Parallel panel
Features Low profile
Length 40.64 cm
Connector 25 pin D-Sub (DB-25) - female
Connector (Second End) 26 PIN IDC - female
Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Low Profi...
£5.79
