StarTech.com Low Profile TV Mount - Tilting
£45.37
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save space with this flat-screen TV wall mount for 37" to 75" TVs (fits curved TVs, with compatible VESA mount)
  • Low profile TV mount sits only 2" (51 mm) from the wall
  • Tilts -10 to +5 degrees for optimal viewing
  • Stock Status: In Stock
Product codes
Save space while improving the appearance of your working area with this low-profile TV wall mount. The mount sits close to the wall to support a VESA Mount compliant TV from 37" to 70", and offers anti-theft protection as well as titling capability that makes it easy to find the perfect viewing position.
Product Description StarTech.com Low Profile TV Wall Mount - Tilting - Anti Theft - Flat Screen TV Wall Mount for 37" to 75" TVs - VESA Wall Mount (FPWTLTBAT) - wall mount
Product Type Wall mount - wall-mountable
Dimensions (WxDxH) 98.5 cm x 5.1 cm x 44 cm
Tilt -10° to 5°
Adjustments Tilt
Weight 3.9 kg
Recommended Use LCD / plasma panel
Recommended Display Size 37"-70"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight 40 kg
Material Plastic, steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 6 x concrete anchors, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws, 6 x screws, 6 x circular washers, 4 x rectangular washers
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Low Profi...
£45.37
