StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power
£6.19
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect an IDE hard drive and a floppy disk drive to a Serial ATA power connector on the power supply with a single cable
  • Easy to use and install
  • Backed by StarTech.com's lifetime warranty
  • Length: 0.15m
  • Type: Power
  • Stock Status: In Stock
Product codes
This LP4 to SATA Power Adapter Cable features an LP4 female connector as well as an SP4 female power connector and a SATA power connector, allowing you to connect an IDE hard drive as well as a floppy disk drive to a Serial ATA power connector provided by the computer power supply. This high quality LP4/SATA power adapter cable is expertly designed for durability.
Product Description StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power (LP4SATAFMD) - power adapter
Type Power adapter
Connectors 15 pin Serial ATA power - male
Connectors (Second End) 4 PIN internal power - female , 4 PIN mini-power connector - female
Colour Black
Designed For P/N: DRW110SATBK, PEX2M2, PEXM2SAT3422, S251BU31REM, S25SLOTR, SATSASBP425
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com LP4 to SA...
£6.19
