This rugged M.2 NVMe PCIe SSD enclosure is a highly portable, high-performance data storage solution for your USB-C or Thunderbolt 3 enabled devices.
Product Description | StarTech.com USB-C 10Gbps M.2 NVMe PCIe SSD Enclosure, Rugged Aluminum External M.2 PCIe M-Key Case IP67 Rated, 1GB/s Read/Write, Supports 2230/2242/2260/2280, TB3 Compatible, Mac/PC - 1.6ft USB-C Cable Incl - storage enclosure - M.2 Card - USB 3.2 (Gen 2) | Device Type | Storage enclosure - external | Bus Type | USB 3.2 (Gen 2) | Colour | Black | Expansion Bays | 1 x internal - M.2 2230/2242/2260/2280 | Hard Drive Form Factor Compatibility | M.2 | Interface | M.2 Card | Data Transfer Rate | 10 Gbit/s | Supported Devices | Solid state drive | Max Storage Devices Qty | 1 | Product Material | Aluminium | Dimensions (WxDxH) | 10.5 cm x 4.5 cm x 1.4 cm | Weight | 100 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: PEXUSB321C |
General | |
Host Bus | USB 3.2 (Gen 2) |
Colour | Black |
Storage Controller | |
Processor | JMicron JMS583 |
Expansion / Connectivity | |
Interfaces | 1 x PCIe 3.0 - M.2 NGFF M Key |
Connections | 1 x USB 3.2 (Gen 2) - 24 pin USB-C |
Miscellaneous | |
Included Accessories | Screwdriver, rubber feet, drive mounting stand-off |
Cables Included | 1 x USB-C cable - external - 5 cm |
Features | UASP transfer protocol, bus powered, 4Kn drive compatible |
MTBF | 50,000 hours |
Compliant Standards | FCC, RoHS, WEEE, REACH |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 10.5 cm |
Depth | 4.5 cm |
Height | 1.4 cm |
Weight | 100 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 17 cm |
Shipping Depth | 14 cm |
Shipping Height | 3 cm |
Shipping Weight | 220 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
