StarTech.com M.2 PCIe Adapter w/ Chassis
Product codes
The Thunderbolt 3 m.2 enclosure lets you take advantage of the speed and size of PCIe M.2 internal solid-state drives, connected externally to your Thunderbolt 3 desktop or laptop computer. This Thunderbolt 3 to PCIe M.2 adapter lets you take advantage of the speed of PCIe solid-state drives, connected externally to your Thunderbolt 3 desktop or laptop computer. The adapter combines the StarTech.com Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and the M.2 PCIe SSD adapter card (PEX4M2E1), giving you a DisplayPort output and an additional Thunderbolt 3 port.
Get ultra-fast data access by adding this PCIe M.2 SSD adapter externally to your existing Thunderbolt 3 computer, using the Thunderbolt 3 chassis - improving your storage performance and expanding overall capacity. The adapter supports PCIe M.2 SSDs (NVMe and AHCI): 2242, 2260, 2280, and 22110 drives.
Connect additional displays through the chassis' dedicated DisplayPort output and second Thunderbolt 3 (USB-C) port (USB-C video adapter may be required). With two extended displays, you can multitask effortlessly, avoiding the hassle of repositioning open windows or programs repeatedly throughout your workday.
You can assemble and connect the adapter in minutes. Put it together using only a screwdriver then plug and play with no software or drivers required.
Product Description StarTech.com Thunderbolt 3 to M.2 PCIe Adapter - External PCIe Enclosure / Chassis plus Card - with DisplayPort Monitor Port - PCIe SSD (BNDTB4M2E1) - interface adapter - M.2 Card - PCIe x4
Device Type Interface adapter - plug-in card - low profile
Bundled with Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Bus Type PCIe x4
Supported Form Factor Expansion Slot to M.2
Expansion Bays 1 x internal - M.2
Hard Drive Form Factor Compatibility M.2
Interface M.2 Card
Supported Devices Solid state drive
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
