StarTech.com M.2 SATA Enclosure with USB-C
£31.15
Delivery:
Standard: 1-3 working days
Key features
  • Leverage your SATA M.2 SSD to add fast external storage to your USB-C enabled host (USB-C cable included)
  • Supports USB 3.1 Gen 2 (10Gbps)
  • Compatible with Thunderbolt 3 USB-C port
  • Type: Storage enclosure
  • HD Size: M.2
  • Stock Status: In Stock
Product codes
Turn your M.2 NGFF SATA drive into an ultra-fast, ultra-portable storage solution for USB-C enabled devices. This compact M.2 SSD enclosure lets you add highly portable data storage to any laptop or computer with a USB-C port - such as MacBook, Chromebook Pixel, Dell XPS laptops, and many others. It turns your SATA M.2 drive into a high-speed storage solution over a USB 3.1 Gen 2 connection, at up to 10Gbps throughput.
This slim, pocket-sized M.2 NGFF SSD enclosure has been specially designed for mobility, with a small form factor design that fits easily into your laptop bag. Its lightweight yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move.
Ventilation holes help to dissipate heat and help ensure an optimum operating temperature.
Leverage the speed of your M.2 NGFF SATA drive with this external enclosure. It delivers USB 3.1 Gen 2 data transfer speeds up to 10Gbps as well as UASP support, so you can achieve higher transfer speeds when you connect it to a UASP-enabled host computer.
The enclosure works with tablets, laptops and desktop computers and is compatible with hosts equipped with Thunderbolt 3 USB-C ports.
The enclosure is compatible with all of the common M.2 SSDs, and enables you to mount multiple drive lengths, including: 30mm (2230), 42mm (2242), 60mm (2260), and 80mm (2280).
Product Description StarTech.com M.2 SSD Enclosure for M.2 SATA SSDs - USB 3.1 (10Gbps) with USB-C Cable - External Enclosure for USB-C Host - Aluminum (SM21BMU31C3) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Device Type Storage enclosure - external
Bus Type USB 3.1 (Gen 2)
Colour Black, silver
Expansion Bays 1 x internal - M.2
Hard Drive Form Factor Compatibility M.2
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Solid state drive
Max Storage Devices Qty 1
Product Material Aluminium
Dimensions (WxDxH) 8 cm x 1.2 cm x 9.85 cm
Weight 55 g
Designed For P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com M.2 SATA...
£31.15
