StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1...
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2
£29.26
47 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Turn your SATA M.2 SSD into external storage for your USB-C laptop, tablet or desktop computer
  • Ultra-fast USB 3.1 Gen 2 data connection for M.2 SATA drives
  • Compact solid aluminum design (4x2x1.5” / 11x5x1.4 cm) with ventilation and attached braided cable
  • Type: Storage enclosure
  • HD Size: M.2
  • Stock Status: In Stock
Product codes
Add high-performance external data storage to your USB-C laptop, tablet or desktop computer, with this SATA M.2 SSD enclosure. It lets you use your SATA M.2 drive as an ultra-fast external storage solution over a USB 3.1 Gen 2 connection. It's ideal for your MacBook, Dell XPS, Chromebook Pixel or other USB Type-C device.
The compact M.2 SATA to USB adapter is easily portable and gives you high-speed access to your data, wherever you go. The integrated USB-C cable (6"/15.2 cm), means you're always ready to plug it in, without having to remember to bring along a cable.
The sturdy aluminum and plastic enclosure encases your M.2 SATA SSD and features built-in ventilation that improve heat dissipation to help keep your drive at a suitable operating temperature.
Easily use your M.2 SATA drive as external data storage. This M.2 NGFF SSD enclosure provides a simple connection to your M.2 SATA SSD over USB 3.1 Gen 2. You can transfer files quickly, without bottlenecks, using a SATA M.2 SSD as your external drive.
The enclosure supports common M.2 SATA SSDs and multiple drive lengths, including: 42 mm (2242), 60 mm (2260), and 80 mm (2280). The USB to M.2 SATA enclosure works with USB-C host devices and is also compatible with Thunderbolt 3 USB-C ports.
Product Description StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB-C - storage enclosure - M.2 Card - USB 3.1 (Gen 2)
Device Type Storage enclosure - external
Bus Type USB 3.1 (Gen 2)
Colour Black
Expansion Bays 1 x internal - M.2 2242/2260/2280
Hard Drive Form Factor Compatibility M.2
Interface M.2 Card
Data Transfer Rate 6 Gbit/s
Supported Devices Solid state drive
Max Storage Devices Qty 1
Product Material Aluminium
Power Source USB bus
Dimensions (WxDxH) 11 cm x 5 cm x 1.4 cm
Weight 95 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com M.2 SSD E...
£29.26
