StarTech.com M.2 to U.2 Adapter
£26.89
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Increase your system speed and performance cost-effectively, by adding an M.2 PCIe NVMe SSD to your PC or server
  • Adapter supports one M.2 PCIe NVMe SSD (M-Key)
  • U.2 (SFF-8639) host interface
  • Stock Status: In Stock
Product codes
Add the fast performance of an M.2 NVMe SSD to your desktop computer or server by converting the drive through a U.2 (SFF-8639) compatible interface on your motherboard. This PCI Express M.2 to U.2 adapter makes it easy to install an M.2 PCIe NVMe SSD into your desktop PC or server, and connect to the drive through an available U.2 (SFF-8639) compatible interface on your motherboard.
The M.2 to U.2 adapter is ideal for IT professionals, system integrators and installers, and enthusiasts who are building or upgrading a server or desktop computer. It supports one M.2 PCIe NVMe SSD (M-Key), providing a cost-effective way to add M.2 NVMe performance to your computer or server through an available U.2 (SFF-8639) compatible interface on your motherboard.
The M.2 to U.2 adapter works with all desktop PCs and servers that have an available drive bay or a U.2 (SFF-8639) compatible host interface. The adapter card is OS independent, so there are no drivers or software required for installation.
Product Description StarTech.com M.2 to U.2 Adapter - For M.2 PCIe NVMe SSDs - PCIe M.2 Drive to U.2 (SFF-8639) Host Adapter - M2 SSD Converter (U2M2E125) - interface adapter - M.2 Card - U.2
Device Type Interface adapter - external
Bus Type U.2
Colour Red
Expansion Bays 1 x internal - M.2 2242/2260/2280
Hard Drive Form Factor Compatibility M.2
Interface M.2 Card
Supported Devices Solid state drive
Max Storage Devices Qty 1
Dimensions (WxDxH) 7 cm x 10 cm x 0.7 cm
Weight 33.4 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com M.2 to U....
£26.89
