StarTech.com Micro HDMI to VGA Adapter Converter for Smartpho...
StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080
£27.44
Delivery:
Standard: 1-3 working days
Key features
  • Simple plug and play adapter, for a quick and hassle-free setup
  • Compact design with no need for an external power adapter ensures a portable solution with a minimal footprint
  • Stock Status: In Stock
Product codes
Connect a Micro HDMI equipped Smartphone or Tablet PC to your VGA Display, or Projector. The MCHD2VGAE2 HDMI Micro to VGA adapter/converter actively converts an HDMI Micro video signal from your smartphone, Ultrabook, or tablet PC onto a VGA projector, or display. The Micro HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor.
The HDMI Micro/VGA adapter supports video resolutions up to full 1080p, making it a convenient option for high-definition applications, and features a compact design with no external power source, which ensures a portable solution that's easy to carry as an accessory.
Product Description StarTech.com Micro HDMI® to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 - Micro HDMI Male to VGA Female (MCHD2VGAE2) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Dimensions (WxDxH) 4.5 cm x 25.5 cm x 1.5 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Micro HDM...
£27.44
