StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Rea...
StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices
£9.43
Delivery:
Standard: 1-3 working days
Key features
  • Expand the storage capabilities of your smartphone or tablet with support for OTG-enabled devices
  • Hassle-free setup with Plug-and-Play installation
  • Maximize portability with an OTG/USB-enabled storage device with a small footprint and lightweight design
  • Stock Status: In Stock
Product codes
Connect a Micro SD card to your computer or OTG mobile device, through a USB or Micro USB port. The MSDREADU2OTG Micro SD to USB/Micro USB Adapter lets you turn a Micro SD card into an external USB storage solution that can interface with any USB-enabled computer or OTG-enabled device, such as Samsung Galaxy smartphones and tablets.
Expand the storage capabilities of your OTG-enabled smartphone or tablet, by creating an external storage device that you can also connect to your USB-enabled computer, and transfer files from one device to another with standard USB and Micro USB interface options.
Maximize portability by creating a compact, external storage solution that you can connect to your smartphone, tablet or laptop computer. For a hassle-free setup, the OTG adapter supports plug-and-play installation and is natively supported by any USB-enabled computer or any OTG-enabled mobile device.
Product Description StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices (MSDREADU2OTG) - card reader - USB 2.0
Product Type Card reader - external
Supported Memory Cards miniSD, microSD
Host Interface USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Micro SD...
£9.43
