StarTech.com Micro USB to RS232 DB9 Serial Adapter Cable for...
StarTech.com Micro USB to RS232 DB9 Serial Adapter Cable for Android with USB Charging - M/M
£26.61
33 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: Android
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
Add an RS232 serial port to your Android smartphone or tablet device through Micro USB with USB charging capabilities. The ICUSBANDR232 Micro USB to Serial Adapter Cable for Android converts the micro USB port on your Android mobile device into an RS232 DB9 connection, letting you control a serial device from the convenience of your smartphone or tablet.
Plus, you can keep your Android mobile device charged even when using the adapter to control or configure a serial device. The adapter cable features an integrated USB power cable that connects to a computer USB port, USB wall charger or portable USB battery pack to power the adapter.
Designed for mobility and integration into mixed environments, this portable and lightweight single cable solution is compatible with nearly all Android OS version 3.2 Honeycomb or later devices including the Samsung Galaxy Note, S5, S4, S3, or S2, Google Nexus 7, 5, or 4, and Motorola or HTC mobile devices. The versatile adapter will even work with devices that don't support USB On-The-Go (OTG)!
This Micro USB to serial adapter features an integrated FTDI USB UART Chip supporting baud rates up to 921.6 Kbps, provides serial configuration via a downloadable FTDI AOA (Android Open Accessory) HyperTerm Application, and offers standard CTS/RTS, DTR/DSR, XOFF/XON flow control.
Product Description StarTech.com Micro USB to RS232 Serial Adapter Cable for Android with USB Charging - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports RS-232
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Compliant Standards USB 1.1, USB 2.0
System Requirements Android 3.2 (Honeycomb) or later
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Micro USB...
£26.61
