StarTech.com microSD card reader - USB-C
£14.65
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Supported Formats: microSD, microSDHC, microSDXC
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
Transfer photos and video from your microSD card to your USB-C or USB-A enabled computer. Here's a fast and easy way to access the data on your microSD card. This compact card-reader adapter lets you connect a microSD card to your computer's USB-C or USB-A port, so that you can quickly offload the files and data you've saved on your portable devices.
Now you can easily transfer the files from your smartphones or digital cameras to your computer, or use your microSD card as a thumb drive.
Quickly offload the data from your microSD card onto your computer. This USB 3.0 card reader gives you fast and convenient access to files from smartphones, digital cameras, camcorders and any other devices that use a microSD card. It's the ideal solution for quickly transferring high-definition videos, high-resolution photos and other files to your computer, through USB 3.0 data transfer speeds of up to 5Gbps. The adapter is also backward compatible with USB 2.0, 1.x.
The card reader adapter works with microSD (Secure Digital), microSDHC (Secure Digital High Capacity) and Micro-SDXC (Secure Digital eXtended Capacity) cards.
The unique design of the microSD card-reader adapter features both a USB-C and USB-A interface, providing versatile use with laptops, computers or other host devices with a USB-C or USB-A port. You can also use the micro SD card as a portable thumb drive with USB Type-C and USB Type-A host.
The compact, lightweight design makes this adapter easy to take with you, anywhere you go. Use the pocket-sized card reader to share content quickly from your smartphone, digital camera, or other device.
Product Description StarTech.com microSD to USB 3.0 Card Reader Adapter - USB C and USB A - card reader - USB 3.0
Product Type Card reader - external
Supported Memory Cards microSD, microSDHC, microSDXC
Host Interface USB 3.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com microSD c...
£14.65
