StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft...
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m
£34.80
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Reduce clutter with a USB-C to mDP adapter and cable in one
  • Get astonishing picture quality with support for UHD video resolutions up to 4K 60Hz
  • Make the perfect connection with a Mini DisplayPort cable that works with any USB Type-C enabled device
  • Type: DisplayPort
  • Length: 1m
  • Stock Status: In Stock
Product codes
Use this cable to connect your USB Type-C computer directly to a Mini DisplayPort monitor, without additional adapters. This USB-C to Mini DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your Mini DP monitor. The adapter offers a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For longer installations, StarTech.com also offers a 1.8 m (6 ft.) USB-C to Mini DisplayPort cable (CDP2MDPMM6B), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
Product Description StarTech.com 1 m / 3.3 ft. USB-C to Mini DisplayPort Cable - 4K 60Hz - external video adapter - STM32F072CBU6 - black
Device Type External video adapter
Bus Type USB-C
Graphics Engine STM32F072CBU6
Max Resolution 3840 x 2160
Interfaces Mini DisplayPort (male connector) , USB-C (male connector)
Dimensions (WxDxH) 2 cm 1 cm
Length 1 m
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£34.80
