StarTech.com Mini DisplayPort to DisplayPort Adapter Converte...
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F
£22.22
30 in stock
Delivery:
Standard: 1-3 working days
  • Type: DisplayPort
  • Stock Status: In Stock
Product codes
The GCMDP2DPMF Mini DisplayPort to DisplayPort adapter/converter allows you to add a standard DisplayPort connection port to your existing laptop or Mac Mini. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
Product Description StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - Mini DP (m) to DP (f) Converter Adapter (GCMDP2DPMF) - DisplayPort adapter
Type DisplayPort adapter
Connector DisplayPort - female
Connector (Second End) Mini DisplayPort - male
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPLPORT10L, DISPLPORT15L, DISPLPORT3L, DISPLPORT6L, DP2DVIADAP, DP2HDS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£22.22
