StarTech.com Mini DisplayPort to DVI Active Adapter
£17.06
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Supports display resolutions up to 1920x1200 at 60Hz
  • Works with video cards that aren't capable of outputting DP++ (multi-mode) signals
  • Compliant with DisplayPort 1.1a specifications
  • Supports HDCP 1.3
  • Compatible with Intel Thunderbolt
  • Stock Status: Clearance
Product codes
The MDP2DVIS Mini DisplayPort to DVI Active Adapter (single-link) lets you connect your Mini-DisplayPort video source to a DVI-D display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort capable monitor.
Unlike passive video adapters, this Mini DisplayPort to DVI adapter offers an active conversion for use with any Mini DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
Supporting resolutions up to 1920x1200, this compact device provides a simple solution for adapting PC or Mac Mini-DisplayPort output for DVI monitors, televisions or projectors.
The Mini DP to DVI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
Product Description StarTech.com Mini DisplayPort to DVI Adapter - 1080p - Single Link - Active - Mini DP (Thunderbolt) to DVI Monitor Adapter (MDP2DVIS) - DVI adapter - 20 cm
Type DVI adapter - dual link
Features HDCP compliant
Length 20 cm
Connector Mini DisplayPort - male
Connector (Second End) DVI-D - female
Compliant Standards FCC, RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£17.06
