StarTech.com Mini DisplayPort to DVI Video Adapter Converter...
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200
£12.66
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple to use converter makes Mini DisplayPort output backward compatible with your existing DVI display or projector
  • Save time with a simple plug-and-play solution; no software or driver installation required
  • Stock Status: In Stock
Product codes
Connect a DVI Display to a Mini DisplayPort Video Source. The MDP2DVI3 Mini DisplayPort to DVI Adapter lets you connect your Mini DisplayPort video source (desktop PC, laptop, etc.) to a DVI monitor, projector, or display, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports display or projector resolutions up to 1920x1200 (WUXGA) and is compliant with HDCP standards.
MDP2DVI3 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description StarTech.com Mini DisplayPort to DVI Adapter - 1920x1200 - 1080p - Dongle - Monitor Adapter - Mini DisplayPort Adapter - Mini DP to DVI (MDP2DVI3) - DVI adapter - 17 cm
Type DVI adapter
Length 17 cm
Connector Mini DisplayPort - male
Connector (Second End) DVI-I - female
Compliant Standards FCC, RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£12.66
