StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 5m
£21.51
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Astonishing video quality with support for video resolutions up to 4K at 30 Hz
  • Reduce clutter with a 5 m adapter cable
  • Avoid the hassle of converters that require additional cabling and power adapters, with a plug-and-play cable adapter
  • Stock Status: In Stock
Product codes
Eliminate clutter by connecting your mDP computer directly to an HDMI display, using this 5-meter cable. This 5-meter (15 ft.) Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable works with your 4K HDMI display and video source to ensure you it maintains it's astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 5 m in length, this adapter cable delivers a direct connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, a 1-meter mDP to HDMI cable (MDP2HDMM1MB), a 2-meter mDP to HDMI cable (MDP2HDMM2MB), and a 3-meter mDP to HDMI cable (MDP2HDMM3MB) enable you to choose the right cable length for your custom installation needs.
Product Description StarTech.com Mini DisplayPort to HDMI Adapter Cable - 5 m (15 ft) - 4K 30Hz - video cable - DisplayPort / HDMI - 5 m
Cable Video cable - DisplayPort / HDMI
Length 5 m
Colour Black
Connector Mini DisplayPort - male
Connector (Second End) HDMI - male
Compliant Standards DisplayPort 1.2
Features 4K support
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£21.51
