StarTech.com Mini DisplayPort to HDMI Video Adapter Converter
£11.90
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Hassle-free connectivity with plug-and-play mDP to HDMI video adapter
  • Maximum portability with a small footprint and lightweight design
  • Crystal clear picture quality with support for high-definition video resolutions up to 1080p
  • Stock Status: In Stock
Product codes
The StarTech.com MDP2HDMI Mini DisplayPort HDMI Adapter Cable offers a cost-effective HDMI/Mini DisplayPort link, letting you connect an HDMI display to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility.
MDP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
  • Simple to use, small form factor converter makes Mini DisplayPort backwards compatible with your existing HDMI display or projector
  • No installation software or drivers required providing a simple plug and play solution
  • Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
  • Easy to use cable, no software required
Applications
  • Ideal for digital entertainment centers, home offices, business conference rooms and trade show displays
  • Keep your existing HDMI monitor to be used with your new Mini DisplayPort device
  • Ideal for using your HDMI monitor as a secondary display
Product Description StarTech.com Mini DisplayPort to HDMI Adapter - 1080p - Thunderbolt Compatible - Mini DP Converter for HDMI Display or Monitor (MDP2HDMI) - video adapter - DisplayPort / HDMI - 76.2 mm
Cable Video adapter - DisplayPort / HDMI
Length 76.2 mm
Colour Black
Connector Mini DisplayPort - male
Connector (Second End) HDMI - female
Designed For P/N: DP2MDPMF3, DP2MDPMF6IN
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£11.90
