StarTech.com Mini DisplayPort to VGA Video Adapter Converter...
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White
£18.07
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple to use, small form factor converter makes Mini DisplayPort backward compatible with your existing VGA display or projector
  • No software or driver installation required, providing a simple plug and play solution
  • Length: 17cm
  • Stock Status: In Stock
Product codes
Connect a VGA display to a Mini-DisplayPort -equipped PC or Mac computer. The MDP2VGAW Mini-DisplayPort to VGA Adapter (White) offers an easy-to-use VGA/Mini-DisplayPort link that enables you to connect a VGA computer monitor to a device with a Mini-DisplayPort output (such as a laptop video out port) or video card.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a Mini DisplayPort video source to a VGA monitor without sacrificing video quality.
Product Description StarTech.com Mini DisplayPort to VGA Adapter - White - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA Converter (MDP2VGAW) - video converter - white
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Dimensions (WxDxH) 4.5 cm x 18 cm x 1.5 cm
Enclosure Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Disp...
£18.07
