StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and...
StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F
£14.64
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 20cm
  • Stock Status: In Stock
Product codes
This Mini DVI to HDMI Adapter cable features one 32 pin mini-DVI Male and one HDMI Female connector, allowing the video signal from a mini DVI equipped device to be output to an HDMI equipped TV set or A/V Receiver.
This is the perfect solution for using your HDTV instead of a computer monitor, or watch movies directly on your TV from your Apple MacBook or iMac Computer.
MDVIHDMIMF will not work with the current MacBooks, it is made for MacBooks that use mini DVI connectors
Product Description StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F - MacBook Mini DVI Adapter - Mini DVI to HDMI Cable (MDVIHDMIMF) - video adapter - HDMI / DVI - 20 cm
Cable Video adapter - HDMI / DVI
Length 20 cm
Colour White
Connector Mini-DVI - male
Connector (Second End) HDMI - female
Designed For P/N: HDMIROTMM6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini DVI...
£14.64
