StarTech.com Mini PCI Express Gigabit Ethernet Network Adapte...
StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card
£40.50
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Built-in NDIS5 Checksum and Large Send Offload support and Jumbo Frames minimize system resource usage
  • Full length mini PCI Express (PCI Express Mini Card, Mini PCIe) form factor fits in many Mini-ITX or embedded systems
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Form Factor: Plug-in card
  • Compatibility: Mac, PC, Unix
  • Type: Network adapter
Product codes
Add a Gigabit RJ45 port through a Mini PCI Express slot. The ST1000SMPEX Mini PCI Express Gigabit Network Adapter Card adds 1000Mbps network connectivity to a Mini PCI Express (PCI Express Mini Card, Mini PCIe) enabled computer system, such as Mini-ITX motherboards. Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this Mini PCI Express Gigabit Adapter is ready to handle a wide variety of scenarios. Perfect for small form factor or embedded systems that originally lack Gigabit networking capability, or for adding a network connection without taking up a full-sized PCI Express slots, this high quality Mini PCIe Network Adapter includes a low profile/half-height bracket for additional installation options.
Product Description StarTech.com Mini PCIe Card - 10/100/1000Mbps RJ45 Port - IEEE 802.3 - Jumbo Frame - Network Card (ST1000SMPEX) - network adapter
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express Mini Card
Ports Gigabit Ethernet
Dimensions (WxDxH) 4 mm x 5.1 cm x 3 cm
Weight 150 g
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.x - 10.5.x, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini PCI...
£40.50
