StarTech.com Mini Thunderbolt 3 Dock - Dual 4K HDMI
£133.42
Delivery:
Standard: 1-3 working days
Key features
  • Add dual UHD 4K HDMI monitors at 60Hz to your laptop with this portable Thunderbolt 3 docking station
  • Easy to set up and ready to go with no driver installation required
  • Connect your devices with 2x USB-A ports - 1x USB 3.0 and 1x USB 2.0
  • Device Type: Laptop, Macbook
  • Type: Docking Stations
  • Colour: Black
  • Stock Status: In Stock
Product codes
This Thunderbolt 3 docking station packs big performance into a cost-effective, compact mini dock, delivering essential connections for productivity. The bus-powered Thunderbolt 3 dock lets you connect to dual 4K HDMI displays, Gigabit Ethernet and two USB (Type-A) ports. Compatible with macOS and Windows, it's the ideal accessory for your MacBook Pro, Dell XPS or other Thunderbolt 3 laptop.
Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to HDMI dock supports 40Gbps of throughput and 4K resolution at 60Hz on dual HDMI monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources.
Connect your laptop to 2x 4K HDMI displays (up to 4096 x 2160p @ 60Hz).
To enhance your productivity, the Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support) ensures reliable wired network access. A USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, such as a flash drive, for easy file access. Connect another USB device using the USB 2.0 Type-A port.
This mini dual 4K docking station offers a versatile solution for permanent and shared office workspaces. It's bus-powered, with no external power required. For flexible setup, the attached USB-C cable has an extended length of (7.9 in./ 20 cm).
Product Description StarTech.com Dual 4K Monitor Mini Thunderbolt 3 Dock with HDMI - Mac & Windows Docking Station (TB3DKM2HD) - docking station - 2 x HDMI
Product Type Docking station
Docking Interface USB-C 3.1 / Thunderbolt 3
Video Interfaces 2 x HDMI
Dimensions (WxDxH) 6 cm x 12 cm x 1.88 cm
Weight 145.8 g
Colour Black & grey
Networking Gigabit Ethernet
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Thun...
£133.42
