StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Wind...
StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered
£106.93
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Add dual UHD 4K DisplayPort monitors at 60Hz or a single 5K 60Hz display to your laptop, with this portable Thunderbolt 3 docking station
  • Easy to set up and ready to go with no driver installation required
  • Connect a USB-A device with the USB 3.0 port
  • Device Type: Laptop, Macbook
  • Type: Docking Stations
  • Colour: Black
  • Stock Status: In Stock
Product codes
Create a dual-monitor bus powered workstation, with two 4K DisplayPort displays, one USB 3.0 and Gigabit Ethernet port, and flexible desktop setup with extended length cable. This Thunderbolt 3 docking station packs big performance into a compact mini dock, delivering 4K UHD video performance to two DisplayPort monitors simultaneously. Compatible with macOS and Windows, it's the ideal accessory for your MacBook Pro, Dell XPS or other Thunderbolt 3 laptop.
Great for editing 4K video or other Ultra HD tasks, the Thunderbolt 3 dock, with 40Gbps of throughput, supports 4K resolution at 60Hz on two DisplayPort monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays (at up to 4096 x 2160p resolutions) without draining system resources. You can also connect a single 5K 60Hz display to your laptop.
To enhance your productivity, the Gigabit Ethernet port ensures reliable wired network access. Plus, a USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, like a flash drive, for easy file access.
This mini Thunderbolt 3 dock offers a versatile solution for permanent and shared office workspaces, with a compact design that's portable enough to take with your laptop wherever you go. It's bus-powered, with no external power required. For flexible setup, the attached USB-C cable has an extended length of 20 cm.
Product Description StarTech.com Mini Dual 4K Monitor Thunderbolt 3 Dock with DisplayPort - Mac & Windows (TB3DKM2DP) - docking station - 2 x DP
Product Type Docking station
Docking Interface Thunderbolt 3
Video Interfaces 2 x DP
Dimensions (WxDxH) 6 cm x 12 cm x 1.88 cm
Weight 145.8 g
Networking Gigabit Ethernet
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mini Thun...
£106.93
