Portable Projector Cart with Laptop Tray Height Adjustable Cable Management. This all-steel projector and laptop stand enables you to setup a mobile multimedia workstation that you can easily move between classrooms, boardrooms, and conference rooms. It has two device platforms that each support 22lb (10kg). This rolling cart is equipped with durable casters (2 lockable) that provide ease of transportation.
Setup Flexibility
With the two integrated device trays, this mobile projector trolley adjusts to your needs letting you choose where to mount your projector, laptop, and other media devices. Both trays have safety ledges that help prevent your equipment from sliding.
The upper tray has surface area of 13.8"x11.8" and lets you setup a laptop or projector depending on your needs. You can adjust its height (37.4" to 57" from the floor) and tilting angle (+/-12°) to provide a better viewing experience that will adjust to your presentation needs. Adjustments can be made by hand via the rotary knob locks.
The lower tray has a surface of 14.4"x11.8" and it sits at 27" from the floor.
Security and Stability
With a base area of 17.9"x19.7", this AV projector will comfortably support a combined load of 20 kg. For added security, you can keep your devices in place by running straps through the thin openings of the top and bottom trays (straps not included). Additionally, this cart comes with 2 cable management clips that will let you run your cables through the pole in a tidy and safe manner; and help with the transportation of your setup.
ADJPROJCART is backed by a StarTech.com 5-year warranty and free lifetime technical support.
Product Description | StarTech.com Mobile Projector and Laptop Stand/Cart, Heavy Duty Portable Projector Stand (2 Vented Shelves, hold 22lb/10kg each), Height Adjustable Rolling AV Presentation Cart with Wheels - Lockable Casters - cart - for projector / notebook - black | Product Type | Cart | Dimensions (WxDxH) | 45.5 cm x 50.2 cm x 150 cm | Tilt | -12° to 12° | Adjustments | Height, tilt | Weight | 10.6 kg | Recommended Use | Projector / notebook | Max Load Weight | 20 kg | Material | Steel | Colour | Black | Wheels Qty | 4 | Package Content | Hex key, wrench, 8 x nuts, 4 x M6 x 12 mm screws, 2 x cable clips, projector platform, laptop platform, support pole, base cross member, 2 x base feet, 5 x M6 x 65 mm bolts, 9 x washer (Type 1), 2 x M6x30 screws, 3 x M6 X 50 screws (type 1), washer (type 2), M6 X 50 screws (type 2), 2 x casters with brakes, 2 x casters with out brakes, 3 x knobs, 2 x mounting brackets | Manufacturer Warranty | 5-year warranty |
General | |
Width | 45.5 cm |
Depth | 50.2 cm |
Height | 150 cm |
Weight | 10.6 kg |
Material | Steel |
Colour | Black |
AV Furniture | |
Type | Cart |
Shelf Qty | 2 |
Cable Management | Integrated cable management |
Wheels Qty | 4 |
Brakes Qty | 2 |
Dimensions & Weight Details | |
Dimensions | Cart - width: 45.5 cm, depth: 50.2 cm, height: 150 cm , Top shelf - width: 35 cm, depth: 30 cm , Bottom shelf - width: 36.3 cm, depth: 30 cm |
Shipping Dimensions (WxDxH) / Weight | 40 cm x 35.5 cm x 11 cm / 10.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
