Mobile Tablet Stand - For 7" to 11" Tablets - Height Adjustable - Detachable Holder
This rolling tablet floor stand is perfect for delivering presentations and rolling your tablet in environments such as healthcare, education, tradeshows etc. The stand fits tablets ranging from 7" to 11" (6.6" to 7.8" in width) and up to 0.41" (10.5mm) in thickness. Use it with your Apple iPad (including the 10.2 iPad, and 11" iPad Pro) or other compatible tablets.
Perfect for Presentations
This tablet stand on wheels enables you to use your tablet to deliver engaging presentations, while you stay focused on your audience and the content you're delivering. You can use your tablet as a visual cue or teleprompter, without having to hold it or repeatedly look down at it while you're speaking.
With lockable casters and a strong base; this mobile tablet holder offers a great balance between mobility and stability, perfect for photography, videography, and educational environments.
Adjustable Height and Viewing Angle
The ergonomic tablet stand has a height adjustability range of 36.4" to 57.8" (92.5cm to 146.8cm) from the floor so you can adjust it to your ideal height; whether you are sitting or standing.
With full articulation, this tablet holder lets you swivel, rotate, and tilt your tablet to adjust the viewing angle and reduce neck strain while improving your ergonomic posture.
Portable Detachable Tablet Holder
The universal tablet stand comes with a detachable tablet holder. If you need to hold the tablet in your hands, simply detach the tablet holder from the stand and take the tablet with you.
STNDTBLTMOB is TAA compliant and backed by a 5-year StarTech.com warranty and free lifetime technical support.
Product Description | StarTech.com Mobile Tablet Stand w/ Lockable Wheels, Height Adjustable Cart, Universal Rolling Floor Stand for Tablets from 7-11in, Portable Tablet Stand w/ Detachable Tablet Holder, TAA - Ergonomic Tablet Stand - cart - for tablet | Product Type | Cart | Dimensions (WxDxH) | 50 cm x 50 cm x 160 cm | Adjustable Height | 92.5-146.8 cm | Tilt | 280° | Lift | 54.3 cm | Rotation | 360° | Swivel | 360° | Adjustments | Height, tilt, swivel, rotation | Recommended Use | Tablet | Recommended Display Size | 7"-11" | Max Load Weight | 900 g | Wheels Qty | 4 | Package Content | Base, tablet holder, 4 x casters, telescopic pole assembly, pole mounting screw | Manufacturer Warranty | 5-year warranty |
General | |
Width | 50 cm |
Depth | 50 cm |
Height | 160 cm |
AV Furniture | |
Type | Cart |
Tilt | 280° |
Lift | 54.3 cm |
Rotation | 360° |
Swivel | 360° |
Wheels Qty | 4 |
Brakes Qty | 4 |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 32 cm x 11 cm x 79 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
