StarTech.com Monitor Arm - Heavy Duty
£88.24
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Mount a VESA (75x75, 100x100) compatible display 12" to 34", flat screen, curved or ultrawide, with a max weight of 19.9 lb. (9 kg)
  • Landscape-to-portrait display rotation (for use in portrait position, the mount supports ultrawide displays with max width of 35"/88.9 cm)
  • Smooth one-touch height adjustment (up to 13.1" / 335 mm), with the gas-spring arm
  • Stock Status: In Stock
Product codes
Desk-mount your monitor to save space and increase your productivity. Free up space while creating a more comfortable and productive work environment. This desk-mount monitor arm makes it easy to mount your display above your desk or table and adjust the height with one touch for ideal viewing. Its sleek silver finish enhances the aesthetics of your workspace.
This heavy-duty monitor arm helps you save space on your desk or table surface, by enabling you to securely mount a computer monitor from 13" (330 mm) to up to 32" (813 mm) in size and up to 19.8 lb. (9 kg) in weight. It's ideal for many different office applications, such as healthcare or financial settings, shared workspaces, or when you wish to show your display to clients or colleagues.
The desk-mount monitor arm features a gas-spring cylinder that makes it easy to raise or lower your display. You can also adjust the tension according to the weight of your monitor, so you can re-position the monitor height effortlessly at any time. It provides 13.1" (335 mm) of height adjustment to accommodate a wide range of applications. Easy one-touch height adjustment makes the monitor arm ideal for shared workstations with multiple alternating users, such as hot desks.
The full-motion articulating arm makes it easy to find the right viewing angle. You can swivel your monitor 180 degrees to share your display, while collaborating with others. The articulating arm also supports 180-degree rotation, so it's easy to switch from landscape to portrait orientation, and back again. You can also tilt your screen +90° to -90° for comfortable viewing.
The single-monitor arm is designed to ensure that mounting your VESA compatible monitor is fast and easy. It requires minimal assembly and features a detachable VESA panel that makes it simple to attach or remove your monitor. The monitor arm also offers built-in cable management that helps keep your cables out of sight to create a clean, sleek look.
Product Description StarTech.com Desk Mount Monitor Arm - Full Motion Articulating - Monitors 12" to 34" Adjustable VESA Single Monitor Arm - Desk & Grommet Clamp -Silver (ARMPIVOTHD) - desk mount (adjustable arm)
Product Type Desk mount (adjustable arm)
Pan 180°
Lift 17 - 50.5 cm
Rotation -90° to 90°
Adjustments Tilt
Recommended Use LCD display
Recommended Display Size 13"-32"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 9 kg
Material Heavy duty aluminium
Colour Silver
Designed For P/N: ACCSMNT
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Monitor A...
£88.24
