StarTech.com Monitor Mount w/ Articulating Arm - Grommet or D...
StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount
£77.89
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Raise or lower your display using only a finger, with the gas-spring height adjustment cylinder
  • Place your display at an optimal viewing angle, with a flexible articulating monitor arm
  • Maximize space-efficiency by mounting your displays above the desk surface
  • Accessory Type: Bracket
  • Stock Status: In Stock
Product codes
Mount a display on your desk surface or through a grommet, with gas-spring height adjustment and cable management. The ARMPIVOTE Articulating Monitor Arm lets you mount a display to your desk or table, with extension, tilt, pan, swivel, pivot and gas-spring height adjustments.
The desk-mount monitor arm features a gas-spring cylinder to raise or lower your display with minimal effort, plus it offers a wide range of motion on several axes. For viewing longer pages or blocks of code without scrolling, the LCD arm also supports landscape to portrait display rotation.
Mounting your displays on a monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 11lbs (5kg), the monitor mounting arm holds your display with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile monitor mounting solution.
Product Description StarTech.com Desk Mount Monitor Arm - Full Motion Articulating - Monitors 12" to 34" Adjustable VESA Single Monitor Arm - Desk & Grommet Clamp - Black (ARMPIVOTE) - mounting kit
Product Type Mounting kit - desktop
Mounting Components Articulating arm
Adjustments Pan, tilt
Recommended Use LCD display
Recommended Display Size 12"-24"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 5 kg
Material Plastic, steel
Colour Black
Designed For P/N: ACCSMNT, ARMSTS, STSCART
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Monitor M...
£77.89
